Hi All,
Im trying to connect my Reach RS+ Rover to a PLC with RS232 serial connection.
I have some questions about the output:
currently i use the following RS232 settings:
Baudrate = 14400
Data bits = 8
Patirty bit (checkbit) = N
Stop bits = 1
idle time between two characters = 1
number of receive buffers = 30
Length of receive buffer = 512
The String i receive in each output format is unreadable.
example:
XYZ Format:
Output string:
’ßÌÄàÄÄÄÄ$$ÄÄìÄ$p$pÄàÄÄÄÜÂÌÌìÌ$04$04ÄàÌÌ$1C$pÄÌÌ$1C$04$pìÌØìÞÌÄàÌÌÚ$$ãÌÄìÄ$pÒÄàÌÌÌ$pÌ
example with NMEA format:
‘$1C$p$04$p$18$12$p$04À$pÄ$1C$18ß,ä"$1C$18Ä$04$p$$$1C$1CÂ’
Am i missing something?
I tried with different settings and baudrates.
But the output string always seems to be unreadable.
setup
Emlid Reach RS+
9pin connector
D-sub connector
B&R X20 CP3584 with RS232Module IF1020
Any help is welcome!
