At first startup I did the update. Upon completion of downloading, ReachView showed the update was installing, but went into a continuous scrolling battery led loop (this lasted about 10 minutes initially before I tried resetting it). I have tried turning on/off numerous time, have doe a few hard-resets, and every time I turn it on the battery LEDs just scroll in an endless loading loop. It connects to WIFI (multiple different ones that I initially set it up on.
I have a project this weekend to use it on. Any feedback is greatly appreciated!
Please contact us at support@emlid.com with the device Serial Number and order date and number.
You can get the Serial Number by scanning the QR code under the SIM card slot.
Also, since you can connect to Wi-Fi, could you try opening the updater page in the address bar (Reach_IP_address:5000) and, if it’s possible to access it, send the screenshot of the updater to us? It helps us to check whether Reach fails any tests or not.
The device is not recognized when it’s connected to wifi. I have even removed it from WIFI area and connected to the reach wifi directly to my mobile device, and it still doesn’t recognize the unit in the ReachView or ReachView 3 apps.
When it’s in hotspot mode, it has a defined IP address. If the Wi-Fi LED is white and you can connect to Reach’s network, you can try opening the 192.168.42.1:5000 in the browser
