We are trying to connect our Emlid RS2 to an echo sounder (Lawrance HDS 12 Live). We have followed this guide: [Networking 3rd Party GPS/GNSS into Lowrance - BioBase Automated Mapping]When we are trying to stream the positions the Emlid app says “Stream is off”. I can’t see what I’m doing wrong in my setup.
The output position settings are set to:
Serial.
Device: UART
Baud rate: 4800
Format: NMEA
I have attached some photos of the “problems”.
Are there any who how an idea of what I’m doing wrong?
May I ask you to share your hardware setup photos? I’d like to check the Reach RS2 to an echo sounder connection: just to exclude any possible issues with that.
Also, I’d recommend double-checking you specified the same baud rate on both devices.
According to the tutorial you mentioned, the Reach RS2 should be a Talker in the scheme. So, it is necessary to connect Reach RS2 TX wire to the adapter RX+ wire. The RX- adapter wire should be connected to the Reach RS2 Ground pin.
