Has anyone successfully used an Emlid RS2 in combination with a robotic total station for hybrid positioning and faster prism lock? If so, what equipment are you using? I’m in the market for a RTS (probably used) and would like to keep my current gear if I can mix+match it all.
Hi Jared,
The idea sounds exciting! We haven’t tried anything similar, but probably our users can share their projects with you. From our side, I’d only note that you can get Reach position in real-time via Serial, TCP, or Bluetooth.
It’ll be cool if you post your results here if you do the integration. I’d like to be in the forefront to read about it
