I have both and hoping to use as base rover setup. Thanks
Use the RS2 as a base so you can use tilt-comp on the RS3 if you want.
Hi @chrisctrl,
Welcome to the forum!
@michaelL made a great point about using the RS2 as your base to take advantage of the RS3’s tilt-compensation feature. Just to add on, here are some guides that might help with your setup:
