Rs2/rs2+
What type of key and size to unscrew and open RS2 and RS2+ ?
Torx ? Allen ? other ?
Hi @FrTmu,
We don’t recommend opening the unit as it will void its IP67 protection and can lead to further issues. Can you send a description of your issue to support@emlid.com? We will look into it.
Hi Alesia,
i understand about IP67, but i have two emild that are not in worhing well, (RS2 and RS2+) i just want to see what append. Il is not a problen if after the two RS will be full dead.
Let me know which key to use.
I do not know what the RS2/+/3 size is, but the old RS uses 6 point T10 TORX.
Get yourself a multi sized tool to try.
Either way, see if Emlid will help before opening it and if not… well, go from there!
I answer to mylself and confirm:
To unscrew and open RS2 and RS2+ you need à 6 point T10 TORX 40 mm long minimum
@FrTmu,
Thank you for the update.
For anyone else reading this thread, please reach out to us at support@emlid.com before disassembling your device. We will look into your case. Opening the device voids the warranty, and it’s difficult to investigate what’s happening with the device after that.
