Trying to make sure that I am entering the rod and antennea offset height correctly
UsinG Fieldgenius for Android.
Instrument is “user defined” is selected
entered ht from ground to bottom of RS2 unit,
then it askes for "Vertical-Measure point to APC " which I entered 134 mm
it also has box "Vertical-Measure point to APC-L1 which I left at 0mm
My elipsoid elev reading are coming out about 0.37 feet lower than what the point actually is.
.37 feet is close to 134mm so I am wandering if I understand what I am supposed to enter.
Thank You
