Hello Friends
My RS2 is having a lot of bad gnss signal as the photos behind
I have been testing in diferent places.
There is any configuration that could solve this?
Sorry for my english
Hello Friends
Can you post some images of you setup ?
Do you have some other electronic components close to the RS2?
Hello!
So im using the rs2 to record raw data (ubx files) for my ppk system.
Look at my configurations for this … im testing in my backyard as the picture behind but i have been using in diferent places with the same result … bad signal … well i live in the mountains, i dont know if this changes the question.
Hi @vitorsig,
At first glance, the survey site and placement look fine. But the logs quality is indeed poor.
Can you share the log files? And also the Full system report from your Reach. I’ll check if everything operates correctly from the hardware side. I suggest sending it to support@emlid.com as it contains sensitive info.
thanks for your feedback.
I just send the e-mail with the full system report and the logs.
Received the email! Give me some time to check, and I’ll share the results.
Hi Vitor,
Something quite interesting is happening here. Take a look:
L2-signals in general are more vulnerable to some RF noises on a site. So, I’d check if it looks the same way in another place. Do you have a chance to check that? This way we’ll know for sure if it’s a unit or site-related issue.
Hello, thanks for your feedback.
Thats intersting.
I will test in other place asap and send you the logs.
Hi Vitor,
Have you had a chance to conduct a test?
I have a broken phone … i will return with the logs next weeek.
thanks in advanced
Hi Vitor,
Sorry for your phone!
Don’t want to push you, but I’m very interested in your case. Because if it repeats on another site, we would really like to investigate it further. Don’t want to leave it as it is.
Hi Svetlana,
Just sent you the log from our new test.
Thanks for your support.
Hi Vitor,
This time it looks much better. Both L1 and L2 signals are good:
L2 signals have a lower SNR overall, but don’t let it frighten you as it’s OK for L2 frequency.
It seems something indeed affected satellite reception badly on the first site. But the receiver itself works fine.
If you notice something weird again, please let me know.
Hello Svetlana,
Thanks for your feedback, the logs look better indeed.
Let’s work!
Have a nice week!
