I am trying to use RS2 with AgOpenGPS via AGIO. AOG needs a nmea GGA and VTG which are provided by position output by RS2.
However, when bluetooth is selected and all other nmea sentences are turned off and only GGA and VTG left a write error message results when hitting apply.
I found the solution to the problem, the position is not displayed the first time you set it up in AgIO on the Com ports page. The position is coming in if you select the gear icon and specifically select GPS data.
But I do notice a new issue I had not had before, where I am unable to receive corrections over Bluetooth but this is also on the AgIO side. Something is messed up with how AgOpen GPS is handling the Bluetooth ports.
Hi! Yes, it is at 10 Hz so the advise on the rtk rate divisible by the nmea rate is not a concern. I am just wondering why writing the nmea sentences results in a write error. And yet agio receives nmea sentences but aog do not pick up the latitude and longitude. Thx
