Dear Community,
I’m trying to convert trimble rover in PPK with Trimble GPS Pathfinder Office.
I use a Geo6000 centimetric accuracy and RS2 as base station.
I produced Rinex 3 .obs base station files for my observations time during my survey.
Now, i want to post process all of those data :
I successfully created my Trimble base station in PFO.
But, the rinex 3 .obs format is not recognized by Trimble… They want some .dat or some .%%o files.
Do you have an idea to convert my larged .obs files into .%%o files ? (it is daily recording).
I tried Trimble to rinex converter (does not worked because it needs .dat, .tgd, .t00 -> .t04)
I tried RTC conv to export in rinex 2 or 3, but convert stucks during convertion. No files created.
Dear, thank you very much for your reply, i already tried to doing it, Trimble does not read file.
I successfully achieved this operation by passing through EZsurv software.
So, to resume for all, this how i solved my problem, using OnPoz, EZsurv (which is a non-free software):
Export RS2 raw data in rinex 3 zip file
Unzip it. If raw data is >500 Mo, split file while conserving or editing it to add header informations, and format all split epochs
Import rinex files in EZSurv (it will check file integrity).
Right Clic on it >Export to Rinex > choose your folder
Launch PFO
Create your personnal base station, enter your local coordinates in 0 " ’ format
Use your local .%%o files previously exported in EZsurv in the PFO post-processing windows
You should not have this error message:
-------------------------------------------------Impossible
And you should have this successfull message (in our case in french sorry):
--------Détails de couverture:--------------------
Fichier du mobile: xxxxxxxxxxxxx.ssf
Heure lcoale: 27/07/2020 16:24:27 à 02/08/2020 11:16:09
98% couverture totale
