Not knowing specific database, you can probably export various layers etc.
Personally I would grab it either via QGIS, or export from a web-interface, if they have one?
But I actually you are better off calling the public instance that manages the database and ask them what is possible.
Do you plan to use LINZ as an NTRIP correction source for Reach RS2?
Also wanting to do rough construction boundary setouts, is this possible? How can we do this?
You can stake out separate points with the ReachView 3 Survey tool. If you need some additional options and know an app that supports them, you can integrate Reach with it. For Android apps, I’d recommend using the Mock location feature.
Hi Jack, I recently used a RS2 receiver as a rover while connecting to a LINZ base station via NTRIP. You will need to sign up with the LINZ PositioNZ service. Once you have an account you simply enter the account details into the RS2 in order to receive corrections. Let me know if you need any further help.
As for boundary setouts you might be best to make use of a 3rd party app like Field Genius, I think the Reach 3 app is a little limited when it comes to cadastral work.
