RS2 Mobile questions
Hello everyone.
I’m trying to create a mobile GIS with Qfield and RS2. I would like to understand some points.
For me the easiest way is to connect Emlid Flow with Qfield using BT (NVME).
But I understand this documentation in a different way : https://docs.emlid.com/reachrs2/integration/mock-location/
Using this method will make my land survey more precisely? (Adding the correct)
I understand this method like that:
Connect NTRIP client with EmlidFlow with BT connexion, then open field.
Don’t know if both are the same or not.
Thanks to everyone helping me
Hi @topo1,
Welcome to the community! I checked that QField supports connecting to external GNSS positioning devices via NMEA message. This way, you can connect your phone via Bluetooth to the Reach RS2 directly.
Could you share more about the Bluetooth (NVME) on your integration?
Hello and thank you @merryna.anggriani,
I can connect my GNSS (RS2) with Qfield with wifi an Bluetooth (NVME). Everything is at 1Hz for NVME setting.
So at present I can creates points with my Emlid RS2.
Do you have more documentation or peoples in charge of Emlid Software to build plugin or anything else.
Thank you for your fast reply.
Could you share more what kind of plugin that you’re referring to?
For now I didn’t use any pluggin. Im only with Qfield and I want to understand if it’s possible to collect the same information in Emlid Flow but with Qfield. (like Averaging start,Averaging end, Samples, PDOP, GDOP, Base easting, Base northing, Base elevation, Base longitude, Base latitude…)
Because, now I can have some of the same information but not all the same.
That’s why I wonder if i need to use a pluggin or if there is some datasheet to collect those data directly with Qfield. (or other app)
I’m sorry if the explication are bad. I’m French
Hi @topo1,
Streaming the different NMEA messages is an option for getting such values into QField. However, we don’t have plugins for collecting the points with the same details in QField as in Emlid Flow.
Are there any features you use in QField and, thus, prefer it to Emlid Flow? If so, please let me know, and I’ll make sure to register your request.
