What is the resistance of the lora antenna when bending, internally does it have a rigid or flexible element?
With patience I was able to disassemble the antenna, you can see where the thread broke. I also don’t see a collinear element for more performance! I think they should think about improving the Lora antenna. I thank Emlid for sending a free antenna.
Can you post of a more close of shot of the antenna part itself? It looks almost like spring?
Since my iphone 7 failed, I can’t take good pictures with Redmi8. I will try a better photo
I purchased an external LoRa radio set from eByte.com. After upgrading to FW 2.24 it seems the RS2 LoRA system was the same as the external setup I purchased. I got 1.2km before signal loss and that was through multiple houses and trees. It would be nice to find an antenna that screwed in then folded upright (2 joints).
Hey there,
I just wanted to say that the RS2 LoRa antenna has the same resistance specs as the Reach RS2 unit. It should be rather rugged.
Thanks You Polina
