Hi everyone, it’s been a long time since I checked about the RS2, yesterday we updated to version 31 and today I put the RS2 to charge (5V 2Amp charger and USB “C” Emlid Cable) and it’s been 4 hours and only one led went up, has anyone else had this problem?
Greetings
I think with the battery technology, best to keep plugged in when not in use?
Bad Google translation, we use the equipment daily with very good results, which I wanted to state that we had no problems with the RS2 for a long time, the slow charging problem was solved, it was not a problem with the update but with the USB cable, I changed it for another and it charged very quickly !!!
Thanks to the Emlid team for a good product!
Greetings
Mala traducción de Google, los equipos los usamos a diario con muy buenos resultados, lo que quería exponer que hace mucho tiempo que no teníamos problemas con los RS2, solucionado el problema de carga lenta, no era problema de la actualización sino del cable USB, lo cambie por otro y cargo muy rápido!!!
Gracias al equipo de Emlid por buen producto!
Saludos
Hi Gabriel,
Thank you for your kind words! Glad to know using another USB cable helped.
