My RS2 does not connect to the NTRIP network of the California Real Time Network (CRTN). I am only able to retrieve single solutions from satellites in view (not float). I’ve attempted to reconnect the RS2 to the NTRIP stations over the past 10 hours with no success. This is unusual because I have been able to connect the RS2 to CRTN for the last 7 months without fail, including a brief 1-hr-long interval of useage about 24 hours ago. Since the successful connection to CRTN just yesterday, I made no changes to the settings of my phone, RS2, or ReachView 3. At present, the status of the CRTN stations (updated every 5 minutes on their website) shows the stations are working. This seems to suggest that my current inability to connect the RS2 to CRTN stations is probably related to my device or its settings.
In summary, NTRIP corrections using CRTN are not working on my RS2. The failed connection to the CRTN is unusual because of its abrupt onset.
Edit (Aug 1): I actually updated the ReachView 3 app. The problem I have began immediately after the update to Version 6.4.
Any suggestions towards a solution would be greatly appreciated.
Current ReachView version: 2.25.2-dev
ReachView 3 Version 6.4
System report:
Simple system report
app version: 2.25.2-dev
current_network:
ip: 172.20.10.7
security: wpa-psk
ssid: iPhone
enabled: true
mode: client
base_mode:
base_coordinates:
accumulation: 120
mode: single-and-hold
output:
io_type: tcpsvr
settings:
cloud:
mount_point: ''
lora:
air_rate: 9.1099999999999994
frequency: 902000
output_power: 20
ntripsvr:
address: ''
mount_point: ''
password: '***'
port: -1
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 9001
tcpsvr:
port: 9000
rtcm3_messages:
message_1004:
enabled: false
frequency: 1
message_1006:
enabled: true
frequency: 0.10000000000000001
message_1008:
enabled: false
frequency: 1
message_1012:
enabled: false
frequency: 1
message_1033:
enabled: false
frequency: 1
message_1074:
enabled: true
frequency: 1
message_1084:
enabled: true
frequency: 1
message_1094:
enabled: false
frequency: 1
message_1124:
enabled: false
frequency: 1
message_1230:
enabled: false
bluetooth:
enabled: false
pairing:
discoverable: false
pin: '***'
correction_input:
base_corrections:
io_type: ntripcli
settings:
bluetooth:
send_position_to_base: false
cloud:
mount_point: ''
send_position_to_base: true
lora:
air_rate: 2.6000000000000001
frequency: 902000
output_power: 20
ntripcli:
address: 132.239.152.175
mount_point: P654_RTCM3
password: '***'
port: 2103
username: Redacted
serial:
baud_rate: 38400
device: ttyEXTS0
tcpcli:
address: localhost
port: 10001
tcpsvr:
port: 10000
device:
privacy_policy_accepted: true
role: null
usage_analysis_accepted: false
logging:
logs:
base:
format: RTCM3
started: true
correction:
format: RTCM3
started: true
raw:
format: UBX
started: true
solution:
format: LLH
started: true
settings:
debug: false
interval: 24
overwrite: true
network:
tcp_over_modem: false
position_output:
output1:
io_type: bluetooth
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
output2:
io_type: tcpsvr
nmea_settings:
bluetooth:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
serial:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpcli:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
tcpsvr:
gga:
enabled: true
update_rate: 1
gsa:
enabled: true
update_rate: 1
gst:
enabled: true
update_rate: 1
gsv:
enabled: true
update_rate: 1
main_talker_id: gn
rmc:
enabled: true
update_rate: 1
vtg:
enabled: true
update_rate: 1
zda:
enabled: true
update_rate: 1
settings:
bluetooth:
format: NMEA
serial:
baud_rate: 38400
device: ttyEXTS0
format: ERB
tcpcli:
address: localhost
format: ERB
port: 9000
tcpsvr:
format: LLH
port: 9001
positioning_settings:
elevation_mask_angle: 15
glonass_ar_mode: false
gnss_settings:
positioning_systems:
beidou: true
galileo: true
glonass: true
gps: true
qzss: true
update_rate: 5
gps_ar_mode: fix-and-hold
max_vertical_acceleration: 1
positioning_mode: kinematic
snr_mask: 35
sound:
mute: false
volume: 100
