Hallo dear emlid team,
in principal my RS2 with Nokia 4.2 phone, NTRIP and ArcGIS works
- v2.22.4.
- [System report] see below
- Detailed problem description.
I can not switch on the mobile data
Whenever pushing the button to on… the rs2 thinks for some seconds… and comes back to “off”
Here at home via home network, but same behaviour outside
As said, it works in general, but sometimes (as today) this occurs for minutes or hours as today.
rebooting, … RS2 and and the nokia device did not help today.
Your step by step actions.
Picture of the setup and connection scheme.
Specify the exact make and model of the hardware you are integrating.
Configuration:
- Nokia 4.2 Android 10
- SIM: tellink.com belgian multiprovider data (still 70Mb credit
- WLAN here Fritzbox …
System report
Simple system report
app version: 2.22.4-r0
'wifi_status, interface: wlan0':
- wifi_mode: infrastructure
- ip: 192.168.178.37
is_added: true
is_connected: true
is_visible: false
mac_address: 6C:21:A2:92:7B:78
security: wpa-psk
ssid: FRITZ!Box 7560 BZ
uuid: 68a333f9-c945-459d-bdda-1558ec5ed3ec
base mode:
base coordinates:
accumulation: 2
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- 0
- 0
- 0
format: llh
mode: single-and-hold
output:
enabled: false
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1006':
enabled: true
frequency: 0.10000000000000001
'1074':
enabled: true
frequency: 1
'1084':
enabled: true
frequency: 1
'1094':
enabled: false
frequency: 1
'1124':
enabled: false
frequency: 1
bluetooth:
discoverable: true
enabled: true
pin: '***'
constraints:
lora:
frequency:
- - 863000
- 870000
correction input:
input2:
enabled: true
format: rtcm3
path: nw-932444:***@195.227.70.119:2101/MAC_3_2G_NW
send position to base: single
type: ntripcli
input3:
enabled: false
format: RTCM3
io_type: tcpsvr
path: :9028
device: null
logging:
base:
format: RTCM3
started: true
correction:
format: null
started: null
debug: false
interval: 24
overwrite: true
raw:
format: UBX
started: true
solution:
format: LLH
started: true
lora:
air rate: 2.6000000000000001
frequency: 868000
mode: read
output power: 20
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: nmea
path: :9001
type: tcpsvr
rtk settings:
elevation mask angle: 7
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: 1
max vertical acceleration: 1
positioning mode: kinematic
positioning systems:
compass: true
galileo: true
glonass: true
gps: true
qzss: true
snr mask: 14
update rate: 1
sound: null
