I’m trying to get NMEA data from RS2 firmware 28.4 to some radio with UART TTL interface. Because I don’t have RS232-EXT cable I use this cheaper alternative scheme(check the hyperlink):
Bus 002 Device 002: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port
But RS2 doesn’t assign PL2303 USB-to-UART to any /dev/tty*. I know this from the fact that the output command ls /dev/tty* doesn’t change whether the PL2303 USB-to-UART is installed or not. The output of dmesg | grep 2303 is also empty.
Beside when I use the browser interface to set the Position Output device to USB-OTG there is an error
Stream open error
The data LED indicator in PL2303 doesn’t blink at all, indicating there is no data from RS2.
I’m also sure this is not the hardware problem of PL2303 nor USB OTG since both working fine when I install it on my laptop that has USB-C port. Here some command output form my laptop:
lsusb
Bus 001 Device 013: ID 067b:2303 Prolific Technology, Inc. PL2303 Serial Port / Mobile Action MA-8910P
sudo dmesg | grep 2303
[ 6943.115706] usb 1-5: New USB device found, idVendor=067b, idProduct=2303, bcdDevice= 3.00
[ 6943.116750] pl2303 1-5:1.0: pl2303 converter detected
[ 6943.117299] usb 1-5: pl2303 converter now attached to ttyUSB0
Is there any USB-OTG device that actually works? Or I must resolve to user RS232-EXT cable? system.log (7.8 KB)
The RADIO is irrelevant here as long as the RS2 data can’t get pass through the USB2UART. I’ve try all baud rate but it still doesn’t work. USB-PC mode is working because in this mode my PC acts as master and RS2 as salve. But I’m not interested in USB-PC mode.
I believe the core of the problem is RS2 Linux kernel doesn’t recognize PL2303 USB2UART as serial output in USB-OTG mode. In USB-OTG mode RS2 act as master and USB2UART as slave so in this mode RS2 will decide if an OTG is valid or not.
It’s not a very common setup, so I don’t have a quick answer. Your assumption may be correct, but let me check the report you shared via email. Perhaps, it will give me more info. I’ll get back with the news soon.
It took some time to check and test, but this adapter indeed isn’t supported in the Reach firmware. So, I’d go with RS232 cable. It should work for sure.
