I am looking for a damping platform to use with RS2. I know RS+ has one but I didn’t found any for RS2. Do you think the RS+ damping platform can be used for RS2 with a thread adapter? I am also wondering if the LoRa extension cable (the one included with RS+ damping platform) is compatible.
What type application are you using it on? I am looking at using an RS2 on a farm drainage tile plow. From past history with a Trimble Z Plus antenna we found that supporting it only with the 5/8" bolt, it would crack the plastic body of the globe due to vibration as the entire weight was supported on a small base. To compensate for this we used a piece of 6" PVC which supported the outer ring of the globe and resolved the issue.
I am considering something similar for the RS2 so the plastic body where the 5/8" thread adapter is doesn’t crack. They were very easy to make using only a saw and a dremel tool and extremely cost effective. I call it cheap insurance so you do not damage your instrument.
I was thinking of using it on the roof of a tractor, should be less vibrations there then on a tile plow.
Anyway, better safe then sorry. Thanks for the tip!
