I’m new to the forum and I’m German, which is why my English is not the best.
Following problem:
Since the software update of the RS2 to the latest software v2.24.2, it is no longer possible to establish a connection from the RS2 to the hotspot of the iPhone 11. Sometimes reach connects briefly to the cell phone and a few seconds later the connection is disconnected. Unfortunately I’m at a loss.
Thank you for your answers in advance
for NTRIP, when the reach builds up its hotspot, I can connect without further ado, but it doesn’t work the other way around. The goal would be that the Reach is connected to the iPhone hotspot and receives the NTRIP data and establishes the connection to the app.
yes, that’s exactly how I do it, but when the RS2 tries to connect to the WiFi from my iPhone it fails. If I try it 50 times it might work one time. If it works the connection holds and everything works. every now and then it comes before the reach connects only very briefly about 3 seconds. and then the connection to the iPhone hotspot leaves again.
Just thinking, when is the last time you have reset the iOS network settings? It will cause a loss of passwords, but it’s a pretty easily troubleshooting step. Also, I don’t see that we discussed what version you are on… I am seeing quite a few posts across the internet about more trouble with disconnecting hotspots on v14.x.x.
