You’re most likely working on the 26.3 firmware version. We had this “Undefined” issue there. You can just update your device, and it will go away.
5 hours is the normal charging time for Reach RS2. We usually recommend even more: around 9 hours. Your other unit may indeed charge faster, and it’s ok as well. But in general, we suggest charging the devices overnight.
