Have a RS2+ Base on software 31.8, the base will show online and I will attempt to connect with a Agriculture RTK receiver, it was working previously and the Base hasn’t gone offline as its setup in a permanent location with permanent power source. I am connecting it through my WIFI. It has happened twice in the past week where I would go to connect but I would have to reset the Base to get the rover to connect. What could be causing this as all settings appear to be the same but something stops it from streaming to the caster.emlid.com site?
Hi Anderson,
As @timd1971 I would like you to generate the Full System Report of your RS2+ and note the report contains some personal information, so we ask you to send this to support@emlid.com. And check if the unit is updated to the latest version of the firmware (31.8).
