Hi welcome. Start here and then you can use
free service from www.rtk2go.com and forward data to your rover.
And then read this
Both can be on your same local net.
Just be aware not to connect to rtk2go to long/often without having a base sending data, your IP will be banned for X Minutes/hours. No harm will happen, its just a precaution thing for those rovers that tries to ping their ntrip service for ever.
Thanks. I figured it out over the weekend. That was my mistake. I was trying to put the correction into the base tab on the base instead of the correction tab. All set now.
Just trying my own Ntrip station for the first time. Thanks for all the previous guidance to get me going.
Will the RS2 be able to do this using its own 3g . at the moment the hotspot system is a bit complex to leave at a base station for the day.
