When disconnecting the antenna, the part of the connector with the external rubber part was disassembled. Is it safe to replace it and paste it? there will be no problems with the Lora module?
This was part of the antenna, right?
The SMA mount is still intact?
Yes, everything is intact
Luis, are you able to unscrew what is left from LoRa antenna from Reach RS2?
Could you confirm LoRa connector on RS2 is not damaged?
Hi Dmitriy if I could unscrew the RS2 connector and it is not damaged
Hi Luis,
May I ask you to contact us on the support@emlid.com and provide the order details? We’ll replace the LoRa antenna to you.
I thank you for your concern
