Hello I have a pair of RS2s and a Carlson Surveyor 2 data collector (SurvCE). I’ve combed through the forums and seen that some people have gotten the RS2s to work fine with SurvCE, others not so much. I fall into the not so much category.
The issue seems to be something with the Bluetooth connection. I have gotten it to connect multiple times and once its connected it seems to work fine, but lately SurvCE is refusing to connect to my rover. It will not even show up on the available devices list to connect to Bluetooth. I’ve triple checked my Bluetooth settings on both devices and have no idea why it’s not working.
I’m attempting to run a base/rover setup with my base receiving NTRIP corrections via sim card, and outputting them via LoRa to my rover. I can get them to communicate fine in the Reachview 3 App, but I cannot get the rover to connect to my Surveyor 2 data collector via bluetooth.
Has anyone run into this issue? If you have a RS2 setup with Carlson SurvCE working properly and care to share your settings/setup procedure, that would be great. Thank you
Did the firmware update solve your problem? I was curious which version of SurvCe you were running. I remember a number of years back Carlson had Emlid on their list of supported GNSS hardware. If I remember correctly, they listed V5 and later releases as being supported. Currently, Emlid is not even listed
Carlson indeed delisted us from its software. However, you can connect Reach as a generic NMEA device to work with SurvCE. This video from our dealer can be of help.
