Hi! Is it possible for RS2 to generate BPQ logs?
Hi @marcin
We don’t have support for a BPQ message in the NMEA stream at the moment. All the currently supported messages you can find in this article.
Thank you for your answer. Is there any chance that there will be support for BPQ messages in the future?
At the moment we don’t have plans on adding a BPQ message.
May I know, why do you need it?
I must to make a report with each job with dx, dy, dz value. The program producer said that BPQ log is needed for this.
Hi @marcin,
At the moment Reach receivers are unable to provide dX, dY and dZ values via NMEA. We will add an output for this data in some way in the future. However, we won’t be able to implement the BPQ message.
