I appear to be having the same issue. With both units sitting side by side the rover has 21 satellites but the base keeps jumping from 9 or 10 to 20 or 21every second or so. I have 2 RS+ units running V2.23.6. it’s also showing a base line up to about 50m
Hi @Nilrac,
Please note that the base satellites’ erratic behavior in the Status tab is an indication issue that doesn’t affect the RTK solution. It’ll be fixed in the future releases.
Would you mind elaborating on this issue? Do I understand correctly that the rover shows an incorrect baseline in the Status tab?
