Hi all,
I’m trying to connect a RS+ to the point one nav vrs correction network - it connects fine, but won’t converge on a solution.
I don’t have access to other CORS subscriptions, could anyone else share their experience in connecting the RS+ to single base or VRS cors networks? Trying to establish if the RS+ just doesn’t work on VRS networks, or if there are compatibility issues with certain bases/outputs.
If you see that RS+ is “Receiving corrections” in Emlid Flow but cannot get a Fix solution, that might be related to the baseline. RS+ allows a maximum baseline of 10 km. With a VRS, it can be tricky to know the true baseline since it always shows as a couple of meters. Do you have a different MP, which is not VRS, so you can try to connect to it?
