RS Hotspot Quick Connect Tip
I wanted to share this with others. I found a little trick that helps connect with the hotspots generated by the units faster.
Set the network info in the phone to static and use the following
IP Address: 192.168.42.20
Subnet: 255.255.255.0
Router: 192.168.42.1
This needs to be done for both hotspots that you have (given that you have two units). this cut my connection and access time in Reach view down to mear seconds rather than minutes while it bounced around tyring to get a self id’ed ip adress.
Hope this helps others
