Please, share original CSV file downloaded from the Reach as there’s no info about collection start/end time, solution status, RMS, sample count and antenna height.
Main dam-CSV.zip (663 Bytes)
I think I knew wher is my mistake
During collecting the point in the survey mode it gives me 2m higher, but when I accepted and save it and downloaded from the Reach view it looks good.
Many thanks all of you:heart_eyes::heart
@ bidePro user
@ timd1971
@ andrew.yushkevich
@ wizprodChristian Grüner
What the rms means ? and it appears that if it higher it gives a good result . The reading under hearth from my CSV file.
lateral rms
0.0042
0.0151
0.0102
5.383
points here done by SOKKIA
176
178
180
182
And here done by My RS+
222
224
225
226
Root Mean Square
Seems sokkia point 176 and reach rs+ point 222 is a difference of 0.1860885m (7.326 inches) for example.
The sokkia receivers are multi-frequency correct? vs. Single L1 emlid, so the sokkia would be more accurate for vertical in this case?
Emlid, is the antenna height 2.0865m shown in csv file just for record, but the elevation shown is correct and what to use for the actual point height… as antenna height is already accounted for?
So point elevation isn’t off 2.0865m but 0.1860885m (7.326 inches) off for points 176 and 222?
And for points 182 and 226 is 0.0209 m. It looks good.
