I am having an issue using a RS+ as a base station and a RS2 as a rover. I have set up the Base Station per the tutorial here and the Rover Station per the tutorial here.
Everything looks like it is working, I can see the base signal in the rover but the base satellites literally jumps up and down when connected to the RS2.
This literally happens every 1-2 seconds it will show 8 BASE satellites, then 19, 8 then 19. I have rebooted both units to factory and re-set both up and that hasnt fixed things. I have moved to different locations where I get 23 satellites on both units and the base will do the same thing, 11 then 23, 11, 23.
If I log into the base unit it does not do the same thing, here are a few pictures
It is quite stable, so im thinking the issue is between the data link between the RS+ and RS2. Anyone have any suggestions?
