I updated both my RS+ and RS2 yesterday to the latest version I did some survey after, I was able to connect just fine and finished the survey.
Today I am attempting to connect and download the data, however, I am unable to connect to my Rover (RS+).
Initially I started the unit, and it seemed like it was able to connect to our office wifi as normal. But I could not see it in Reachview. After a few restarts, I took it outside to be out of wifi range and started it that way.
I was able to connect to the RS+ hotspot, however it still does not show up in Reachview at all.
The green LED has been blinking steadily the entire time. I also tried starting up the RS+ and leaving it in the open for 20+ minutes to see the satellites. This green LED was blinking the same while on our office wifi as well.
I should also note that I have tried to connect to it with reachview on my ipad mini, and two different iPhones. I don’t know of any other way to connect.
It’s great to hear that. We would still like to investigate this behavior. Since you now have access to the interface, would you please send us Full system report in support@emlid.com?
We can confirm that there is a software bug on some Reach RS+ units behaving like this after the update. The good news is that we were able to localise the issue and we are working on fix at the moment.
I will let you know once the fix will be released.
I’m reaching out to confirm that we’ve released the new v2.22.6 firmware update that should resolve the issues with the green LED blinking behaviour.
Update is available through the Reach Updater page. All you have to do is to type the following to the address bar: Reach's_IP:5000. A Wi-Fi connection with an Internet access is needed to perform an update.
Please note that the fix for this behaviour in the dev branch will be in the v2.23.9 version. We’re working on the releasing it as soon as possible. I’ll reach out with the update as soon as it will be available.
I updated my RS+ with 2.22.6 and completed two surveys. Unfortunately, I’m attempting to download the data back at the office, and the same blinking green light issue is still happening this time.
