I bought 3 Reach Rs+ and now using in Pakistan.
2 of them updated on v2.22.7 and 1 on v2.22.9
Now when i try to to update RTk setting in v2.22.9 stays at loading stage and doesn’t allow to edit anything. Pictures are attached for reference.
Also see the report
Simple system report
app version: 2.22.7-r0
'wifi_status, interface: wlan0':
- wifi_mode: ap
- access_point:
band: bg
channel: 1
password: null
ip: 192.168.42.1
is_added: true
is_connected: true
mac_address: 6C:21:A2:8F:91:86
security: wpa-psk
ssid: reach-Rover2:41:5E
uuid: 87ecee4b-f871-417f-a9d8-5580dfe37f23
base mode:
base coordinates:
accumulation: 30
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- 0
- 0
- 0
format: llh
mode: single-and-hold
output:
enabled: true
format: rtcm3
path: lora
type: lora
rtcm3 messages:
'1002':
enabled: true
frequency: '1'
'1006':
enabled: true
frequency: '0.1'
'1010':
enabled: true
frequency: '1'
'1097':
enabled: false
frequency: '1'
'1107':
enabled: false
frequency: '1'
'1117':
enabled: false
frequency: '1'
'1127':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
constraints:
lora:
frequency:
- - 863000
- 928000
correction input:
input2:
enabled: true
format: rtcm3
path: ttyMFD2:38400:8:n:1:off
send position to base: 'off'
type: serial
input3:
enabled: false
format: RTCM3
io_type: tcpsvr
path: :9028
device: null
logging:
base:
format: RTCM3
started: true
correction:
format: RTCM3
started: true
debug: false
interval: 24
overwrite: true
raw:
format: UBX
started: true
solution:
format: LLH
started: true
lora:
air rate: 4.5599999999999996
frequency: 868100
mode: write
output power: 20
position output:
output1:
enabled: true
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: true
format: llh
path: :9001
type: tcpsvr
rtk settings:
elevation mask angle: 15
glonass ar mode: 'on'
gps ar mode: fix-and-hold
max horizontal acceleration: 1
max vertical acceleration: 10
positioning mode: kinematic
positioning systems:
compass: false
galileo: true
glonass: true
gps: true
qzss: true
sbas: true
snr mask: 40
update rate: 5
Moreover, we will use Baido satellite in pakistan is there any setting required?
And in both Reach RS+ v2.22.7 when i select status the bars does not go green it stays orange, eventhough i am standing under the sky.
