snsi
1
Having a little trouble with setting up initial setup of an RPi Camera with the Navio2 & Mission Planner.
After running both commands found on the following page:
https://docs.emlid.com/navio2/Navio-APM/video-streaming/
The RPi runs and holds on:
‘Setting pipeline to PLAYING…’
‘New Clock: GetSystemClock’
Gstreamer fails on:
‘WARNING: erroneous pipeline: could not link rtph264depay0 to videoconvert0’
I have comms via wifi from PC running Windows to RPi3.
Apologies if this topic has been covered before & thanks in advance for any advice.
Which Raspbian image you are using? Did you perform update\upgrade?
snsi
3
VERSION_ID="8"
VERSION=“8 (jessie)”
Yes, Update/Upgrade was run a few days ago on initial setup.
Thank you for the response.
Prepend command with sudo
and you should be good to go.
snsi
5
Slightly different error this time:
WARNING: erroneous pipeline: no element “avdec_h264”
Running using sudo, port is confirmed as open on PC as well.
Thanks again.
syk0306
(Syk0306)
6
windows gstreamer install do not choice “typical” …you have to choice “complete” sorry bad english
