Whenever I run sudo APMrover2 -A udp:192.168.1.133:14550 it says it was not found.
I am able to run the copter -quad fine as i have been doing with my navio but on a new sd card with the deb installed as shown below the command is not found.
pi@navio-rpi ~ $ wget http://emlid.com/files/APM/apm.deb
–2015-05-16 18:59:39-- http://emlid.com/files/APM/apm.deb
Resolving emlid.com (emlid.com)… 95.170.83.157
Connecting to emlid.com (emlid.com)|95.170.83.157|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 13373960 (13M) [application/x-debian-package]
Saving to: `apm.deb’
100%[======================================================================>] 13,373,960 561K/s in 24s
2015-05-16 19:00:03 (537 KB/s) - `apm.deb’ saved [13373960/13373960]
pi@navio-rpi ~ $ sudo dpkg -i apm.deb
Selecting previously unselected package apm.
(Reading database … 37132 files and directories currently installed.)
Unpacking apm (from apm.deb) …
Setting up apm (3.1.0a) …
pi@navio-rpi ~ $ sudo APMrover2 -A udp:192.168.1.133:14550
sudo: APMrover2: command not found
pi@navio-rpi ~ $ APMrover2 -A udp:192.168.1.133:14550
-bash: APMrover2: command not found
What could be causing this?
