I am following the tutorial for ROS on the Emlid docs.
After running the command:
rosrun mavros mavros_node
_fcu_url:=udp://:14650@
_gcs_url:=udp://:14551@192.168.8.103:14550
I get the following error:
/opt/ros/kinetic/lib/mavros/mavros_node: symbol lookup error: /usr/lib/arm-linux-gnueabihf/libboost_program_options.so.1.58.0: undefined symbol: _ZTIN5boost15program_options16ambiguous_optionE
I have previously followed the tutorial successfully in the past, and can’t recall changing much if anything since then.
