Hello,
This is a question about the reach_ros_driver. I’m trying to retrieve the NMEA messages for a ROS setup, here are the details:
- EMLID Reach RS2, firmware version 26.1, ip address 10.10.10.3
- Laptop with Ubuntu 18 and ROS Melodic, ip address 10.10.10.5
- ROS package enwaytech/reach_rs_ros_driver
The Reach is connected through WiFI to the same local network than the Ubuntu machine, i can access to the Reach portal over a browser without problems and I can ping from the laptop the Reach without problems.
As recommended, settings in the ReachView web interface are :
On the Position output tab under Output1 choose TCP . Set the role to Server , the address to localhost and choose a port number. From the formats select NMEA .
Then, I start roscore in the laptop, setup the parameters and get the ros node running:
roscore
rosparam set reach_rs_host_or_ip 10.10.10.3
rosparam set reach_rs_port 9001
rosrun reach_rs_driver reach_rs_driver_node
and when I execute the node, I get the following error:
Traceback (most recent call last):
File "/home/usr/ws/t_ws/src/reach_rs_ros_driver/scripts/reach_rs_driver_node", line 45, in <module>
reachRsDriver = ReachRsDriver()
File "/home/usr/ws/t_ws/src/reach_rs_ros_driver/src/enway_reach_rs_driver/reach_rs_driver.py", line 53, in __init__
port = rospy.get_param('~reach_rs_port')
File "/opt/ros/melodic/lib/python2.7/dist-packages/rospy/client.py", line 467, in get_param
return _param_server[param_name] #MasterProxy does all the magic for us
File "/opt/ros/melodic/lib/python2.7/dist-packages/rospy/msproxy.py", line 123, in __getitem__
raise KeyError(key)
KeyError: '~reach_rs_port'
Exception AttributeError: "'ReachRsDriver' object has no attribute 'socket'" in <bound method ReachRsDriver.__del__ of <enway_reach_rs_driver.reach_rs_driver.ReachRsDriver object at 0x7f5ef71fdbd0>> ignored
I think it should be a pretty simple error because I’m basically just executing the package as it is, but i can not get it working…
If any of you has experienced similar issue, I would appreciate your feedback or comments,
Thank you in advance!!!
