Hi all!
Adruplane 4.2, Navio2
clean install roll goes wring way, if i roll to righ, ground station shows as if i roll to left. direction (arrow) to front is correct. Its like im inverted but ground is where its supposed to be
what setting should i change? or maybe i missing something?
Ah, I see. It seems that the accelerometer wasn’t calibrated correctly. So the drone doesn’t show the actual orientation. Have you tried following the instructions from this guide?
