I am using the latest STUDIO 1.4. The trouble is that I am using CORS data which has 5 navigation files separate for each satellite constellation and the input accepts only one. I have tried with the ROVER mixed P file but results were not that good. Is there any utillity that can combine all those files into the mixed one? Can I load more tha one navigation file?
Hi Darko,
Emlid Studio allows importing several navigation files simultaneously. You need to select them in the folder and drag & drop into Studio. Otherwise, you can press on Navigation and select them in the file system.
The rover mixed navigation file should work fine in most cases. You can send me your raw data logs, so I can help you with post-processing. Since there’s a sensitive data, you can share them via PM or send to support@emlid.com.
