Hi Team,
I have the below problem with the RINEX Header… Can anyone shed any light on the below?
I had to change the file extensions to get them into Leica Infinity (.obs->.19o abd .nav ->.19n). This did the trick and the data came in nicely.
Problem is that there are a couple of key pieces of information missing from the RINEX file header:
No IGS Receiver type, which is needed for the post-processing software to compensate for GLONASS inter-frequency biases.
No IGS Antenna name, which is needed for the pos-processing software to compensate for the phase center offsets.
3.01 OBSERVATION DATA M: Mixed RINEX VERSION / TYPE
CONVBIN 2.4.3 Emlid 20190416 223901 UTC PGM / RUN BY / DATE
log: raw_201904162229 COMMENT
format: u-blox COMMENT
MARKER NAME
MARKER NUMBER
MARKER TYPE
OBSERVER / AGENCY
REC # / TYPE / VERS
ANT # / TYPE
-4529967.2740 707569.4662 -4419343.5533 APPROX POSITION XYZ
0.0000 0.0000 0.0000 ANTENNA: DELTA H/E/N
G 4 C1C L1C D1C S1C SYS / # / OBS TYPES
R 4 C1C L1C D1C S1C SYS / # / OBS TYPES
E 4 C1C L1C D1C S1C SYS / # / OBS TYPES
J 4 C1C L1C D1C S1C SYS / # / OBS TYPES
S 4 C1C L1C D1C S1C SYS / # / OBS TYPES
C 4 C1I L1I D1I S1I SYS / # / OBS TYPES
2019 4 16 22 29 49.3920000 GPS TIME OF FIRST OBS
2019 4 16 22 39 19.7920000 GPS TIME OF LAST OBS
One clue is that the RINEX file say’s it’s been converted from u-blox format, which indicates that it’s a u-blox receiver inside.
I’ve had a search through the IGS receiver and antenna lists and can’t find any u-blox stuff:
http://www.epncb.oma.be/ftp/station/general/rcvr_ant.tab
I’ve even tried hacking the RINEX header with ‘u-blox’ but Infinity doesn’t recognize it.
It might be worth checking with the manufacturer if they have the receiver and antenna types registered with the iGS or at least have antenna calibration files available (absolute or relative in ANTEX format).
