Hey. I’m about to acquire a drone in the next few months to do a LIDAR survey with PPK. I was wondering if Emlid Studio was able to convert the last RINEX formats 4. to previous versions in order to use it in RTKLib. I couldn’t find any rinex files 4. to make a test.
Cheers,
Laura
Hi Laura, welcome to the community!
Emlid Studio supported RINEX format until the 3.03 version, but the difference between RINEX 3.03 and 3.04 is not that much.
You can try to convert it in Emlid Studio, it most probably should work, but if it doesn’t, I believe there are conversion tools that can do the job.
Hello laura,
RTOOLS can help you to convert, merge, modify RINEX of versions 2, 3 and 4 including OBS and NAV files.
Hi, thanks for your replies. I’ll check that once I’ll get my first dataset.
