Hello,
Is there a guide getting rinex from rs2 and using it in third party software? Currently unable to use rinex from rs2 but from other rover is possible(topcon)
Thanks
Hello,
Thanks
Hi Siim,
Please update ReachView to the latest version (v2.16.26), we’ve fixed RINEX logging on board of RS2 in this release.
In case it’s still incompatible with your software, you can use this guide to convert UBX to RINEX:
Hello Dimitry, thank you for fast reply,
Currently still having probleb getting PPK fix for our drone: No solution found
I have reachview to latest version:
app version: 2.20.6-rs2-rc0-r0
'wifi_status, interface: wlan0':
- wifi_mode: infrastructure
- ip: 192.168.8.189
is_added: true
is_connected: true
is_visible: false
mac_address: 6C:21:A2:93:14:D0
security: wpa-psk
ssid: HUAWEI-B525-1F5A
uuid: 2a05255a-a9ab-45c9-ab34-37ae207a4949
base mode:
base coordinates:
accumulation: '2'
antenna offset:
east: '0'
north: '0'
up: '0'
coordinates:
- '0'
- '0'
- '0'
format: llh
mode: single-and-hold
output:
enabled: false
format: rtcm3
path: tcpsvr://:9000#rtcm3
type: tcpsvr
rtcm3 messages:
'1006':
enabled: true
frequency: '0.1'
'1074':
enabled: true
frequency: '1'
'1084':
enabled: true
frequency: '1'
'1094':
enabled: false
frequency: '1'
'1124':
enabled: false
frequency: '1'
bluetooth:
discoverable: false
enabled: false
pin: '***'
correction input:
input2:
enabled: false
format: rtcm3
path: sirius1:***@000000080/Win1
send position to base: single
type: ntripcli
input3:
enabled: false
format: rtcm3
path: :9028
type: tcpsvr
logging:
base:
format: RTCM3
started: false
version: null
correction:
format: RTCM3
started: true
version: null
interval: 24
overwrite: true
raw:
format: RINEX
started: false
version: '2.10'
solution:
format: LLH
started: false
version: null
lora:
air rate: 2.6000000000000001
frequency: 868000
output power: 20
position output:
output1:
enabled: false
format: nmea
path: bluetooth
type: bluetooth
output2:
enabled: false
format: llh
path: :9001
type: tcpsvr
output3:
enabled: true
format: llh
path: :2014
type: tcpsvr
output4:
enabled: true
format: llh_ext
path: :2015
type: tcpsvr
rtk settings:
elevation mask angle: '13'
glonass ar mode: 'off'
gps ar mode: fix-and-hold
max horizontal acceleration: '1'
max vertical acceleration: '1'
positioning mode: kinematic
positioning systems:
compass: false
galileo: false
glonass: true
gps: true
qzss: false
snr mask: '32'
update rate: '1'
You can upload logs from base and rover you are trying to process here or on the cloud storage so we can check them. I believe something small should be missing
Here is the logs: https://drive.google.com/drive/folders/1Iuikr4JVV1SMwvrH-jCyOUia2TmGK9XA?usp=sharing
Your data processes (converts) just fine in RTKlib.
What 3rd party software are you trying to use, and what is the error?
Error : No solution found
We are using wingtra drone with sptentrio ppk module
I think you missed this part of the wizprod’s question:
wingtrahub
Not much information available on it, it seems, and the things I can find are in Spanish, which isn’t my strong side, to put it mildly
I think you will need to contact the makers of Wingtrahub instead, and provide them with the data.
Here is the software guide Install WingtraHub
PPK Module: Get started with WingtraOne PPK
Thanks for link, however, the software doesn’t seem to work without this step, which I cannot do:
Step 4: Insert one-time license activation USB stick and PPK license dongle
Can you process your RS2 data in Wingtra if you make it L1 only ? Maybe it doesn’t like the L2c signal that the RS2 is receiving.
I get error message: No solution found
Yep, but that can be a lot of different things, sadly… That error is very generic.
Two rinex files: one working (topcon) and one does not (emlid):
https://drive.google.com/drive/folders/1C3egi0hfeqL-JuY6jQbQjW7LmYyBt6Em?usp=sharing
Did you try my suggestion above? I know it might not solve your issue, but it will give us an indication of where the issue is.
Siim,
I’d recommend checking with Wingtra support on your issue. There’s not much we can do in this case because error message doesn’t explain much.
Yes, i did, still same error occurs
What does their Support say?
