Hi everyone,
just few words to introduce my topic.
I build up an rtk GPS system by myself based on UBLOX M8T chip.
The system is working so good with rtklib library, I get a stable fix when both receiver base and rover are connected via USB to my laptop. Now I should install a LoRa tadio in order to let the rover and laptop with rtklib work far away from the base.
So I purchased a LoRa module from csgshop and I’m fighting since days for Lora connection to my laptop.
The system layout:
Base: 1 UBLOX M8T receiver w/ a cheap UBLOX antenna + radio transmitter:
Rover (on my tractor): 1 UBLOX M8T receiver w/ a cheap UBLOX antenna + radio receiver (for Base correction)
I connected the radio to my laptop, installed the driver, It’s recognized as:
Silicon Labs CP210x USB to UART Bridge (COM7)
I atart mission planner in order to configure the link but I cannoct connect to the radio.
I set port and baud rate, when I try to connect, a timeout message pupup after 25 seconds.
can somebody help me in a step by step way?
many thanks in advance.
