nemir
(Nemir)
April 24, 2018, 2:46pm
1
Hi everyone,
My senior project is almost due and I really need a professional help!
Could you please tell me how can I add led to navio2 pins !
you can find in the link the codes we added so far but we need a help with the LED part
we using C++
“” Senior_Design_2018_AutoHEX/avoid.cpp at master · p2j2j4/Senior_Design_2018_AutoHEX · GitHub “”"
Thank you
Hello, @nemir !
I can’t open your link
Perhaps Navio2 examples can help you. You can find example with LED in this repository.
Hope it helps!
nemir
(Nemir)
April 24, 2018, 3:33pm
5
Hey, I tried to use the codes in the example yet i still get fail ! I tried python and it worked but I need it in C++
" Senior_Design_2018_AutoHEX/avoid.cpp at master · p2j2j4/Senior_Design_2018_AutoHEX · GitHub "
Thank you and could you try this link i think it works now
@nemir , What was your problem with C++ example?
Do you want to change LED’s status, when ‘ROS_ERROR’ or something else happened?
Please, tell me more about your problem
nemir
(Nemir)
April 26, 2018, 2:37pm
7
briefly, I want to ADD LED to our Navio2 and the code i found ( from LED EXAMPLE ) , it didn’t work but in Paython worked and the Navio2 started to change colors and stuff ! but I need it to be in C++ not Payhton !
Thank you
nemir
(Nemir)
April 26, 2018, 2:39pm
8
Actually if you have anything about LED status when ROS ERROR that will work too !
system
(system)
Closed
August 4, 2018, 2:39pm
9
