Request for EMLID RS3 Antenna Parameters and RTK Survey Code List Guidance
This is Marc from Referent Solutions, Emlid dealers in Spain. Recently, one of our clients purchased an RS3 and requires technical information about the antenna for their projects. Here’s the client’s inquiry:
The client performs calculations and post-processing adjustments using Leica Infinity software, as they have other Leica receivers, total stations, and levels, allowing them to unify all data in one workflow. To accurately process their observations, they need specific details about the EMLID receiver antenna.
The client has shared observations taken with different receivers and needs to know the parameters for each of the received signals, including all constellations and frequencies.
Here we show you the observations with the different receivers:
In order to solve and adjust, they need to know the parameters of the receivers of the different antenna signals.
LEICA Receiver Example
They attempted to declare the EMLID antenna in the software, but require more detailed data.
Could you please provide this information?
Additionally, the client asks what steps are necessary to generate code lists for RTK surveys.
Looking forward to your response.
Best regards,
Hi Marc,
You can check the antenna calibration file on NGS’s website, which contains additional details about the receiver.
It’s possible to import code libraries in CSV format into your Emlid account and use them in your surveys. This guide from our docs provides a detailed explanation.
Thank you, Kornel!
