I bought two RS3s for work. One is the base station, another is the rover. I switched them to NTRIP because I usually collect data within 30 kilometres. I am planning to make the base station permanent.
But it takes me an average of 30 minutes or more to be able to Fix the rover and collect data. I am getting fed up and wondering how other people are using it?
I agree that it shouldn’t take that much time to achieve FIX. We can look into this further. I assume you are using Emlid Caster to pass the corrections. But correct me if I am wrong.
How do you connect to the Internet with the Reach devices?
Are you working in remote areas as well?
Cellular coverage might be a hindrance as sending correction messages needs a stable Internet connection. Especially on the base as if the connection is interrupted it can’t reconnect to it automatically. If you send us a Full System Report to [email protected], we can check if everything is okay with the device.
Have you done any mobile data testing while in the field? You’ll want to pay attention to the ping and jitter values as those will disrupt the stream more than a slow download speed. I had a lot of trouble a few years back when they released 5G and started deprecating 4G in our area. Speeds were fast if you were in the right place but even with download speeds of 30+ Mbps the jitter was super high and everything would time out.
