Should the “ref pos” in the _events.pos file match the position you enter in RTKPOST > Options > Positions > Base Station field? I get the same value whether I select “RINEX Header Position” or “Lat/Lon/Height”.
Thanks for the reply. I renamed rtkpost.ini and re-processed. I still get the same results. I’m not sure where it’s getting the position it’s using for the ref pos field. It’s nearby the corrected LLH position.
They’re .ubx converted to RINEX 3.03 on a PC using RTKCONV.
I thought there might be a file lock issue since the positions are identical on both files whether I use RINEX Header or my own LLH. But I processed using RINEX Header, renamed the .pos file, then re-processed using LLH. Still have identical files.
No problem here. Not sure what causes hickups on yours. Try deleting all version of RTKlib and download/install new latest. Also what OS are you runing?
Could it be a file issue. A mixup or a overwriting issue when creating a new event_pos. file?
Sorry for the slow reply. I have processed the logs on a different desktop PC and they process ok. There is a configuration issue on my lap top. I will try and fix it and reply back.
