Hi Andrew,
Any idea of what is the problem?
I need to know if the board is broken and if I need to buy one again, because my project is on standby…
Thanks
Hi Andrew,
Thanks
Hi @pelepicier,
Can I ask you do the following steps once more:
sudo apt-get update && sudo apt-get dist-upgrade
sudo emlidtool ardupilot
sudo nano /etc/default/arducopter
sudo systemctl daemon-reload
sudo systemctl start arducopter
Also, can you clarify if these steps work with your second RPi?
As for the chip, which one?
Hi Andrew,
I already have done these points twice, always the same problem.
The chip is the ARM X STM32F103.
I tried connecting with QgroundControl : same problem than before, no answer of the device, LED green when starting and turns off after 3 sec.
