Recording Rinex Data with Emlid Reach GNSS Receivers
Hello,
I’m currently working with Emlid Reach GNSS receivers, and I’m wondering if it’s possible to leave the receivers continuously recording Rinex data for post-processing. Are there any limitations or specific steps I should follow to ensure uninterrupted data logging?
Thank you for your support!
Best regards,
Marc
Referent Solutions
Yes, you can continuously record and choose to split the logs anywhere from 1hr to 24hr.
Hi Marc,
Welcome to the community!
I echoed @michaelL that you can continuously record logs using the Reach.
Also, you can specify the setting when the memory is full and the split log intervals:
Screenshot 2024-10-07 at 18.08.00
Depending on the duration of your observation, you might need to supply the Reach with a permanent power supply or a power bank.
I also attach our doc on how to log data for PPK. Hope this helps!
Thank you very much for the information.
Thank you, Michael.
