I’ve bought a RS2 kit.
I would like to know is there such feature that could record a path coordinates?
I use NTRIP +RS2, and I use to record point coordinates. But is it possible to record the path of the way that I walk (holding th RS2?) (like UAV does with kml LOG flights)
thanks
Yep, just enable the logging of the Position (LLH or other formats) in the Logging Tab.
thank you !!
Hi @ziok,
Just wanted to add that you can also use our Reach RS2 online docs to learn more about working with our devices. Logging guide explains how to enable logging and what each of the logs means.
