Much like the users in the “Saving logs to external SD” thread, I’m interested in using the Emlid to continuously record for periods of up to a year, and in conditions that may result in intermittent power.
Whilst it the linked thread has provided one solution, it appears to me that far more suitable solution, at least in our circumstances, would be to reduce the update rate recorded to the output files. A combination of GPS-only and a 0.1Hz update rate would allow us to record for more than a year to the 2GB on-board storage, and be cheaper and simpler than the alternative method. However, as far as I tell, you can only record at 1, 5, 10, and 14Hz (depending on the satellites you choose to record). Is there a way around this?
